My kids had an accident and they broke the soap dish which I believe was grouted to the drywall. Now there is a hole in the drywall and a few of the tiles around seem to have lost their adhesive strength and coming off easily. The house is a 60s one.
I was able to get a ceramic soap dish fitting this hole. Now the questions. I am a newbie and I like diy - have already fixed a few holes in drywall.
1) Are ceramic soap dishes held on by the drywall ? Are there any that can be attached to the studs ?
2) I dont have studs bind this soap dish. Is it better to get a recessed soap dish and install a contraption to fix it to the nearby stud ?
3) Assuming I go with the non-recessed soap dish,
a) Do I need to first fix the drywall (using the wood backer, nailing and then filling with drywall compound) or
b) Should I just put the wooden backer and push the soap dish till the backer ?
4) I assume I should put grout/adhesive paste behind the two loose tiles.
Did I miss anything ? Is there any other way ?
Hope somebody can help.
Thanks
Thanks
