1 - 8 of 8 Posts
Hi everyone, I just added a vent in my condo bathroom, I have a 2.5'x2.5' hole I need to patch.
I had a rough time cutting the hole out and my edges are really rough. I've never fixed rough edges before wondering if you can give me a tip on what I might try to soften or feather the edges as in my pics.
I know my lines are just terrible but I hit so many metal supports and other things I wasn't expecting and the hole had to get bigger and bigger. No excuses, I'm a beginner and this is what I have at the moment.
For best results don't use a weed wacker when cutting drywall.
To patch that opening, get a piece of drywall larger then your current hole. If you don't want to buy a full sheet of drywall, they sell patch pieces at the big box stores.
Put the drywall on the ceiling and trace the patch.
Cut along the trace lines with a drywall saw, (if you dont have a multi tool)
Install your blocking/strapping so you can attach the patch.
Put your patch in the hole, and screw to the blocking, tape, mud, paint.
If your filling the hole the edges won't matter, cut your patch, put it in the hole. then tape with paper tape. Just remove the loose stuff around the edge.
Discussion Starter · #6 ·
Thanks for that tip, I put a 5/8" fire retardant panel up but learned another lesson. The ceiling has 3/4"-1" thick drywall, so I didn't catch that when I was trying to screw the panel up so down it comes and adding some furring strips.
At least I didn't add any material in the cracks...!
Lesson learned measure the old drywall before buying new!!!
· Drywall and Painting Pro
The photo doesn't look like 3/4" to 1". :no:
Did you put a screw in the existing drywall wherever the stud meets the new drywall on the patch? :detective:
That could bring in the old drywall a good bit and also keep the seams from cracking. :thumbsup:
Discussion Starter · #8 ·
Hi SirMixAlot... again I could have used your help!
When I tested the 5/8 and put it up to the wood support I screwed in, the 5/8 was not level, I added a little shim and that fixed it. I read online that a multi story condo requires thicker fire retardant drywall for fire.
I am on to 2nd coat hoping for the best! I still think the skill of laying mud is the hardest!!!
1 - 8 of 8 Posts
