So I'm trying to get a couch into our condo and it will not fit through the front door. The only plausible way would be to get it through the sliding patio door.
Removing the sliding door was very simple but the fixed panel doesn't seem to want to move. It had two plastic brackets on the top and bottom corners and one metal bracket holding it to the wall. Assuming that those were there to keep the panel from moving I simply removed them and tried to slide the fixed panel. It didn't move at all!
There are no visible screws or latches or anything that would appear to keep it from moving. With some effort I was able to move the bottom of the panel but not enough to do anything. It seemed like it wasn't built to be removed that way. I also found caulking on the bottom so I'm thinking that this panel wasn't made to be separated from the frame. And I'd rather not get it out without being able to put it back in the frame. I've done some decent research on the topic but couldn't find anything specific to this door. Any suggestions or recommendations would be very helpful!
I hope to figure this out ASAP! I'm trying to get everything set up for my son's return from the hospital after undergoing surgery to remove a cancerous tumor. Want him to be nice a comfortable! Thanks again for any help!
