Hello,
I can't seem to get a straight answer on this, so I'm hoping someone here can help me.
My porch is a concrete slab that sits over my cold room.
It sits on a wood frame.
The cold room has about 1 foot of it above ground.
The slab has a crack in one corner.
Moisture also soaks into the top 3 to 4 inches or so of the cold room wall that is just below the slab.
So I'm wondering what to do.
Can I fix this? Or should I hire a contractor to completely replace it?
Here are the options I've been advised on so far:
- Replace the entire slab
- Cap the slab with a 1 inch layer or so of concrete. My uncle (civil engineer) recommended using SikaSeal brand concrete but said I would need to find the right type.
- Contractor suggested completely sealing the slab and any part of the cold room that is above ground with NuCrete.
Added bonus is that they can stamped it to our preferred style.
Below are pictures of the:
- Crack in the slab (2)
- Portion of the cold room that is above ground (2)
- Soaked wood frame below the slab (2)
Thanks for any help anyone can give with this.
