First time soldering copper.
I used new water soluble flux and lead free solder, and a regular coleman propane tank.
Like the fist picture in the link that person posted is similar to what I have for one joint, not as bad of a gap but similar. The rest of my joints are all good.
http://ww.homedistiller.org/forum/viewtopic.php?f=15&t=54797
Someone replied to him that they were a pro plumber and said to 'repair' it, he can add flux to just that spot and resolder just that spot.
Thant's what I'm hoping to do only because I have so many other fittings so close to this spot. the heat needed to pop this fitting out to re-do the whole fitting with new sanding and new flux might un-do the surrounding joints. the joint is on a T and about 3 inches to the other side is a slip coupling joint.
I am still researching, but key words to find exactly what I'm trying to do is getting a bit hard to find exactly what I'm looking to do.
One tutorial said if this happens, I can't even re-use the same fitting? I reused other fittings and they look fine.
The waterline with this joint in question has been under pressure for 2 hours and still bone dry. I almost want to just leave it.
Do not recommend shark push fittings. I tried those first and do not like them.
In retrospect, I should have just bought ~$20 in pex and crimps and a ~$75 crimper and returned it after about 10 joints but I did it all with solder.
