1 - 1 of 1 Posts
answer: If you cannot get the horizontal adjustment to move, the hinge threads may be stripped. Instead of shelling out $90 for a new hinge, try this: Just use a tap that is one size larger and a phillips or recessed hex machine screw to match. Re-tap the stripped hole, insert the new new screw, tighten as necessary (follow andersens pdf online) and volia! you just saved $90 or more.
1 - 1 of 1 Posts
