Hi,
Our bathroom is currently in the process of being totally gutted and remodeled. We have discovered some issues with the tile on the floor that was just installed:
1) Some of the corners of the tile (8x8) are raised and sticking up more in places so some areas are not completley flat and level.
2) Some of the tiles are not completely lined up perfectly. They are off slightly by about 1/8 inch or so. This is noticable if you look at it. Most of the areas are fine.
3) Some of the grout is wider in places and narrower in others.
4) Some of the grout is darker in places and lighter in others.
A few facts about the house and the contractor:
1) this is a 'slab' syle house with no basement. So the house is all one level and built on a concrete slab. The tiles were adhered directly to the slab. The floor may have been slightly uneven in places.
2) The contractor's "right hand man" who appears to be a younger junior apprentice type person installed the tile. My initial impression was that he is not a professional tile installer.
My concerns:
1) Should this contractor have hired a professional tile person to install the tile? and not used is apprentice? I feel that the apprentice did an "amateurish" job and that a professional would have done a better job.
2) The uneven tiles could be due to one or both of 2 things: 1) Shoddy worksmanship or 2) uneven concrete slab. If it was due to an uneven concrete slab then-- should he have applied some kind of a compound to make it even?
3) The apprentice supposedly used spacers inbetween the tile. Clearly he didn't use them properly because the grout is wider in spaces and narrower in others.
So basically I want all of these fixed before the project moves forward which will involve asking the contractor to remove the baseboard and the tile and to re-install the whole thing. He would also have to purchase new tile since the existing tile will probably be destoyed when it is removed. Is this unreasonable?
Should I insist that a professional tile installer do the job and not his "apprentice"? I don't want my bathroom project to be a classroom for this kid to learn how to install tile.
The contractor is going to be pissed and may not do this. How do I handle this? We still haven't paid the third and final payment.
As a seperate issue - the contractor himself installed a new window. We wanted a proper wooden window sill on the outside. He made some flat aluminum "sill" that is inconsistent with the rest of the house. We already asked him to fix that as well so he's already pissed about having to do more work. He never consulted with us on what type of sill we wanted--he just went ahead and did it.
Thank you for your adivce and opinions! This is our first home improvement experience and aren't sure how to handle this.
My concerns:
