I'm a few weeks out from my first tile project. We're adding 6" x 36" porcelain tile to our basement's concrete slab.
I'm planning on a decoupling membrane, even though our house is 15 years old and likely settled.
So here goes:
1) which decoupling membrane? I'm guessing Ditra is the best (although pricey!)
2) with large format tile, is a T-lock type of system necessary? Or just a waste?
3) when pressing in tile, how much force do you use?
4) when it comes to cuts, do you all just dry fit first, make your cuts at once, then lay the tile? Or do you cut as you go?
5) I have ordered two pallets of tile from the same lot number: I know you're supposed to mix boxes to help with consistency, but how would you mix a huge order like this? Open a few boxes from each pallet?
That's it for now. I'll reply back when it's time for the wall tile....
So here goes:
