Ceiling joints
I'm posting this thread to, perhaps, help others and/or others to help me. I am a DIY guy and intrigued with drywall mudding. I don't know why I am but I love the finished product. I have finished a few basements and, as of recently, a large dormer room (attic). Most of my learning has been talking with professionals, videos, these types of threads, and trial and error.
I helped finished my friend's dormer room which was a lot of work but a great experience. When I got done with all my fussing over the little imperfections (i.e. butt seams, bubbles, air pockets, sanding, round seams...), I finally said enough is a enough. Texture, prime it, paint it!
Well, I went over there just to check how the walls looked after the texture and primer. I was floored how great all my crown joints (butt seams) looked. The texture guy did a great job (except texture does crack in the corners due to no heat and the room being cold as it was. Fill it with it caulk I say). Which brings me to my point contrary what people say about texture. Well, knockdown texture for that matter:
1) Texture does not cover all the imperfections that you hope it does.
After all my gloating of the walls, I then looked to the ceiling. To my dismay, I can still see all the tapered joints telegraphed in the ceiling even after being textured and primed (I didn't even sand the ceiling). Sucks I know, but the only thing I can hope to alleviate this problem is to prime it again and again with a brush if need be. Like wengang1 said before, applying 2nd coat of primer appeared to make the tapered seams go away. Well, I'm hoping for just that.
Couple of things I know I must of have did wrong. I believe it's a combination of things. The most egregious is that there is not enough mud. However, I did coat everything 3 times, actually 4 or more in some places (butt seams require a lot of mud, get that other bucket of mud if you don't want to see humps in your walls). The crown joints (butt seams) weren't the problem. No bumps and they looked great. Luckily they ran parallel with the light direction from the windows.
In the tapered joints, I believe I pressed too tightly my 6" knife to get the damn tape (moistened in water) to really adhere to the mud since gravity is going to pull it down. In addition, you're looking up, it's uncomfortable and I probably didn't realize how much pressure I was doing with the angle of my knife. And I hate air pockets. No problems there. Then for a next coat I decided to do all purpose (premixed) heavy joint compound AGAIN instead of the lighter joint compound. Well, the heavier shrinks more than the lighter (it's stronger but too much of it will crack). I wanted to use it all up. Perhaps that may have also contributed to the taper joint being visible. I did use the lighter compound for a final coat. There was plenty of drying time between coats...several days in fact. Next time I'll use a 6" then a larger 8" knife, not press as hard, fan it out more and use more lighter joint compound on the ceiling tapered joints. Popcorn texture I think would have easily covered the tapered joints (but I like the look of knockdown). The tapered joints are tight, flush and no problems with the joists.
Well, most joints were tight. Some had a 1/4 inch gap. Be careful of these when taping. Mud in a gap will force itself against the tape creating a bulge. That will show later on when it is dry. I run my finger on it to depress it then add more mud. I notice this a lot on the ceiling since I figure gravity pulls the mud down. Sometimes I see a crease on the center of butt joints but can't feel it. No need to worry, leave it alone if you can't feel it. If it was something, texture will most likely hide it. I made the mistake of sanding the hell out of a seam and still saw the crease, then still went nuts sanding but couldn't feel it. It's the way the different coats of mud dried.
Keeping this in mind, be careful sanding the hell out the center of crown joints. The lighter compound coating outside the center will come off much faster than the heavy compound coating leaving discrepancies in your nice, wide, fanned out joint seam. Hence, the notorious "bulge, or hump" will be left behind on your wall. That's why I barely sand. Only on the last coat, to get obvious ridges out.
Also, I've heard of putting on tape backwards. Weird but true. The tape down the center has an indention. One side indents in, the other side, out. If you you do put it on backwards, the indention is out. I'm beginning to think that is what I see as a crease in some joints. Just cover it with enough mud that's all.
Would all this have fixed the problem? Perhaps, but I do know I concentrated like hell on those crown joints and believe the tapered joints needed just as much attention to detail. That is, I should have checked more regularly with the flat end of my knife to the seam and made sure of it being flush against the light. I took advantage of thinking the tapered joints were easy to conceal. Wrong. Not on ceilings!
I also think priming the walls before you texture is a safe bet. Then you can check you work, fix more problems if needed before applying texture. That too could have affected the joint seams from showing. I did notice the texture being a little different on the mud than the drywall paper itself due to the different absorption rates. Primer equalizes all that.
However, I had several things against me. 1) It's a ceiling. I don't have this problem with the walls. 2) There were two windows on the northeast side that shot up natural light across the ceiling and against the tapered seams that are perpendicular to it. 3) It's a dormer so when you walk up the stairs and poke your head up, unfortunately, first thing you see is the ceiling with that light hitting it. Thankfully, I do know when the ceiling fan and lights go up along with the curtains and other crap in that room, no one will notice.
I am very happy how the rest of the room turned out but the ceiling situation is a blemish to me. I did not expect that at all. Another thing that someone may want to chime in on, is that, eventually I would like to try mixing my own compound than buying premixed. I agree that premix compound is more stiff and heavy to work with. Not to mention my thumb, hands, and shoulders were about to fall off when I finished.
I totally give my up most respect to those that do this for a living. It is an art and does take a lot of talent and the know how. Please don't hesitate to respond, suggest, even criticize my posting. I always want to know how to get better at this.
