1 - 6 of 6 Posts
I need to raise the base of the hearth to accomodate my 2cm granite slab. It is about 3.5 inches here now. I hesitate to use wood due to expansion and code regulations. There was sand in this subspace previously. I of course need to make it level before I measure and put in granite.
Once I figure out support underneath, I plan to add hardibacker, thinset and then granite.
The heat from the fire is not a concern since the new vented gas won't get near as hot as a wood burning fireplace, however we left the fireplace so that it could be converted back for any future owners.
Thanks for any help.
Retired Moderator
If you use wood be sure to hold it back from the fire box a little. I have see people build right up to the fire box and the house caught fire from the edge of the hearth getting so hot. I know you aren't going to burn wood but someone on down the road might.
You could build within 6 inches or so of the fire box with wood and then use something fire proof the rest of the way. I personally wouldn't use sand as a base because something dropped could cause a crack. JMHO
Retired Moderator
If it were mine I would build up with wood except for the area at the edge of the fire box, I would build up a mud base to the height of the wood, install a backer board over the wood and mud then make the install.
1 - 6 of 6 Posts
