1 - 20 of 27 Posts
Going to eventually mount a flat panel above (yes, I know, not recommended... please no comments, I have weighed the cons and am still doing it). The fireplace has yet to be used in the last 5 years. Eventually I will convert it to a vented gas log that is not rated to heat the room.
To date:
Washed/scrubbed/wire brushed the firebox about 8 times before rolling on the high heat paint.
Removed the old mantel and 3 courses of brick in an effort to lower the new mantel placement which will also allow for a lower TV mount.
Running HDMI cable and 18-3 for the IR repeater I want to install. Going to pull some Cat5e also just to have it along with some line for future pulls JIC.
Tile installed. Had to build up the hearth a bit to ensure my opening would fit the stock door I wanted and reduce the door overlap of the tile (I want to see that beautiful tile).
Next step is to grout and begin the wood work. I am going to face it with 1/2 ply that I can paint and then use 1x to create a raised panel look. I have never done this before so it should be interesting.
Any helpful input would be appreciated...any known gotchas...
CooL! Keep the pictures coming on your progress. My fireplace is in dire need of a facelift. I love the work you've done so far. :thumbsup:
Newbie Bill
Looking great. I'm going to follow this thread to see the outcome.
So what (and how) did you put directly onto the brick (right around fireplace opening) and on the hearth in order to install the tile?
Are you going to tile around the front/side of the hearh too?
Discussion Starter · #8 ·
Thanks everyone. This is becoming a weekend only project so updates will be delayed.
This week I really am just trying to get used to the height on the TV. The couch is 15ft away so the angle isn't bad at all. I am starting to like it. More research during the Thursday Night preseason football game is required.
Maybe tonight I can test the IR repeater too. If all goes well then on to the mantel and trim. I believe I have picked out the mouldings and trim profiles I am going to use.
Discussion Starter · #9 ·
Well, not much completed this past weekend but it is starting to take shape. It took alot of time makingsure everything was level. My 4ft level isn't cuttin it.
Discussion Starter · #12 ·
Lumberyard had the pencil moulding I wanted. On to the mantel now. I am probably going to span the windth of the fireplace and wrap the sides. Turn the mantel into the wall. This will seperate the bottom and top. Hope it comes out. I see it my head but to be honest, I am guessing at it. I cannot wait to get it painted (actually I can, painting sucks).
Discussion Starter · #15 ·
Had a new addition to the family this past week so EVERYTHING is on hold.
I did get the HDMI runs terminated in the basement as well as the IR repeater. Moved the cable box, hooked it up and it is F'IN SWEET. Just point the remote at the little sensor to the right of the TV and MAGIC....
Jack of all - master none
Great job of modernizing that. The fireplace in my livingroom looks similar to what you started with. There's a good chance I'll use this thread as a template for when I get around to that project.
It looks nice!
Congratulations on the new baby!!
A newborn just puts a halt to everything....
:laughing::laughing::laughing: Don't worry. It only lasts until they're about 17 or so. :yes::wink:
Super Moderator
It looks nice!
Barb, that was your patriotic post, 1776. :thumbsup:
1 - 20 of 27 Posts
