Do you install fireplace door before laying stone veneer or after the fact?
Suppose you do it "BEFORE", then the installation is clear, you just screw that metal frame to the bricks from inside. Here is my confusion though - doors will be almost (~1/4") flush with the bricks with metal frame overlapping like 2" of top and sides. How do you install stone veneer over it? Especially if edge stones angle over inside
Are you supposed to build a 2x4 frame covered with plywood to add depth over the door?
Now, supposed the answer is "AFTER", how do you hide gaps between uneven stone and metal frame? Do you secure the door frame right through the stone veneer?
