Hi folks. In the house I've been living in for the last few years, one of the two doorbell units stopped working. The older unit is a circular buzzer type which still works. The newer one is a Friedland 8va chime, which has kind of given up the ghost. I did some digging and buried under 8 inches of loft insulation (yes you read that right!) I found a very hot transformer with an output of 8v 1amp, and found eventually after some head-scratching and tracing of doorbell wires, that the two units were wired in series. I've now raised the transformer clear of the insulation and mounted it on a timber batten (with a few mms air gap underneath courtesy of rubber grommets) and wired the two units in parallel. The doorbell units now both work and the transformer is now warm rather than worryingly hot. Will I get away with this, or is there a fire risk from overloading the transformer? (I figured it was a serious fire risk whilst it was buried under the insulation...)
