1 - 15 of 15 Posts
· Property Mgt/Maint
Looks like its next to the cold air return grill. Its closer than I would put it. Really need to check the MFG specs on clearances to combustibles. I would be surprised if said Zero clearance to combustibles.
Thank you. Fortunately, I don't live there. Was looking at places & this just seemed wrong but I can't cite codes :} If it's the cold air return grill - that's metal, right? None of it makes sense to me.
Air return grill most are metal- /hinged-& air filter behind them- don't look like you can open this one... looks as metal return grill is just being used for a shield or just some where to put it??? Take the temp of the wall....Looks too close to me but I am not a fireplace installer.
· Banned
That's just crazy. I don't know what stove that is but I can pretty much guaranty they have completely ignored any and all manufacturer's clearance specs.
I have a (good quality) stove and they get HOT! I've had mine hot enough to turn the top cherry red.
There is also no hearth.... which is code in most places I know of.
I would guess that if an insurance company saw that, they would be uninsurable.
· Banned
Not necessarily.
Indeed there seems to be some form of closet or utility room on that wall where the grille is so I would not be surprised to see that it is a return grille... otherwise I could not see the logic in placing the stove that close.
At any rate if it is a return grille then it leads to another problem... that stove is effectively blocking much of the return air.
Also looks ugly, and takes up more space than needed IMO.... I am not heat expert I am in Florida & most heat in my area is electric heat strips. Common sense tells me this install is NOT correct!! IF common sense is so common-where can I buy some??
1 - 15 of 15 Posts
