i had a pretty good idea of how to do it. I just wasn't sure what types of wood to use, proper nailing techniques, and things like that.Lots of ways to trim a window.....
So it's jamb extensions I'm looking for. I think it could get as deep as 7 ". Will I have a problem finding it that deep?Along with what Ron said, do any wiring, insulate and drywall. Then measure and cut some jamb extensions which will but up against your windows and be flush with the drywall. Decide if you want a sill or not and pick out your trim. One suggestion I would make is to visit either a local lumberyard or a millshop that carries decent trim. Forget the big box stores for this part.
Mike Hawkins![]()
AAAAAHHHHHH! You don't even want to me to get into the cat. She felt the need to p!$$ in every corner in the basement. Every time I try to soak it up with cat litter, and clean it up, it's back a day or 2 later in one of the corners. My wife comes up with this idea to put plastic bags in the corners, since she doesn't like them, and you know what she did? Yup. P!$$ed on those too. At least it's easier to clean up like that. but I think she's going to have to "dissappear" before the basement is done.Sure! Plenty of room for the cat to sit in the window that way.
....or a plant?
DM
