Hi - i'm about to hang a drywall ceiling and I tend to like to map things out in my head before I do so.
The ceiling i'm installing is a replacement for a damaged ceiling - the old drywall was taken out etc., new joists in, and now the new drywall needs to go in. The walls are already there, as they were not damaged. So, i'm going to hang it - i've read that i need to put construction glue on the joists, and do the appropriate spacing for the screws - that seems fine. Question I have is, how do i finish the edges of the ceiling where the ceilings butts up against the vertical walls? Just mud & fiberglass tape the same as I would between two flat pieces of drywall? Or is there a different product/technique for dealing with the 90 degree angle where ceiling meets wall?
thanks in advance,
Matt
thanks in advance,
Matt
