I’m working on a project where I am nailing Luan into 1x2’s. In just one of the panels (perhaps a slightly thinner one?) the nails are going so deep that the Luan is popping back away from the wood strips.
I’m using my Ryobi 16g finishing nailer with 1 inch nails, on the lowest setting.
Aside from using a bit of an angle, any other tips? It’s a relatively high volume so I’m trying to avoid hand nailing.
Thanks in advance!
That's luan for ya. It will have soft spots and voids. That's why it's not acceptable for underlayment on a floor.
Maybe switch to an 18 gauge brad nailer or stapler with less punch, use wood glue behind the luan, and just enough nails to hold it into the glue.
A narrow crown staple would hold it much better
That is what I used and 20 years later when I wanted to remove the luan it came off in tiny shreds, a really hard job. Staples work.
