I have a lamp post outside my house that has never worked. There was an old light bulb in there, which I removed and replaced with a new one. I thought I knew which switch controlled the light, but it didn't end up doing anything. I checked the socket and wires with a non-contact voltage checker and it showed that it wasn't energized.
My problem is that I can't find any switch that controls it. I looked all over the house, including the basement, and nothing that I found controlled the fixture. I even checked the circuit breaker panel and nothing is labeled "outdoor lights" or something similar. I thought about using a circuit breaker finder, but those will only work on an energized circuit. Is there another way to find the circuit without having to pull up the Romex cable or calling an electrician? Thanks in advance!
