I'm redoing the caulk around our kitchen backsplash, which is about 4" high granite that leads to the drywall. There are some sizeable gaps between the granite and the drywall. Not sure if it was just installed poorly or if it has pulled away a little (I mean, I can tell the install wasn't great looking at some of the joints...).
I pulled out all the old caulk, but when trying to put new in, it was sinking down too much. I see backer rod for sale, but not sure if that it what I need. I was worried that if I put it in, it might also get pushed down, but maybe it would just need to support the caulk until it dried? But when I'm smoothing the line I could see it getting pushed down and messing everything up. Could it be glued in place if there is nothing for it to push up against?
Looks like the previous owner used some kind of gray caulk/filler that hardened to a solid rubbery surface, then white caulk on top of that. Any ideas on what would be best to use? Any other filler product, spray foam, etc. that would work?
Thanks!
Thanks!
