1 - 8 of 8 Posts
Hi,
I've removed a cable conduit which was fixed to the wall before the walls were plastered (not by me!). I would like to fill the gap with plaster to get a clean finish prior to painting.
I intent to sand the background and fill with plaster, however I was wondering if I need to reinforce the joint between the new plaster and the old?
Thanks for any help
Can you post a picture so we can see what it is you have to deal with?
Discussion Starter #4
The photo is a close up of a section of missing plaster after removing the cable trunking.
It's about 2 inches wide and 3 metres long, on the internal corner of a stairwell.
Hope that give a clearer picture.
From what I can see there I don't you need to reinforce just a good fill. Are you going to use plaster patch or joint compound?
Plaster can not fill voids that size. Fill it with blue board then tape the joints and plaster it. Then you will need to add a tight coat of joint compound. If you try to use plaster to fill a gap that size it will fail, ie crack.
1 - 8 of 8 Posts
