Hey guys,
Working on installing a new over range microwave and have to get a filler block in since there's overhang in the front.
Is a 3"x3" or 4"x4" block enough? I have some short 2x4 pieces I can cut up but I still need to fill 1/4" gap... I found an old cedar moth-repellent hanger where the hanger piece broke off leaving a small 'shim' of cedar - is it OK to use this to shim that space? I know cedar is soft wood and usually not recommended for supporting heavy weight so not sure.
The other question I have is if I need to secure the filler block to the bottom of the cabinet shelf before drilling the hole for the bolt. Or if the filler blocks can be 'loose' and just have the hole pre-drilled... I'd imagine it might be tough lining all the holes up though when going to secure the microwave?
