Sand is compacted about 97% when it gets dumped from the truck. Its problem is it holds water, which is why crushed rock is good. Put heavy duty vapor barrier under the slab, over appropriate thickness of foam if you are heating the place, and compact your gravel in 4" lifts. 8" should suffice, but ask a local engineer/building department about that. Ensure good drainage away from the slab, and large overhangs on the structure; 3' is nice.Ayuh,.... Sand is the least compactable soil out there,....
Sure, but don't expect too much since it should be free of organic matter. It will need a vigorous feeding program and maintain a moisture content of around 30 percent by weight.Can you plant grass seeds in the builder sand?
Ayuh,.... Not that I think a slab oughta be poured, Without a vapor barrier,....according to a guy who teaches building science (this was posted on the greenbuildingadvisor.com site, but i don't have a linnk), concrete will wick water for about 5 kilometers up. NEVER install a slab without a good vapor barrier. P, EOS. See http://www.buildingscience.com/docu...floor-problems?topic=resources/flooring-probs
