Ok, we got a new fiberglass back door with 15 lites and mini blinds between glass, and a glass transom on top (a $700 door bought from a building contractor for $250). Went to Lowe's and got Minwax old oak stain. Put two coats on Sunday, and loved the depth and shine of it. On Monday I noticed two spots that were a lot darker than the rest and they started knawing at me. Figuring I had a week off and had time to do it better, I tried to remove the two coats of stain with mineral spirits - didn't budge it. I sanded two small areas about 4x4" and THEN found an article that said to NEVER sand fiberglass. Then I went to Lowe's and got something called Lift Off and it removed the stain. Today I put on a coat of Zinzer 123 tinted primer, let it dry, then a fresh coat of stain. It looks like crap so not going to bother with the second coat.
I give up - going to just paint it with exterior acrylic.
Question: Do I remove the stain again with Lift Off? Or can I just put another coat of Zinzer over the one coat of new stain, then paint over that with the exterior acrylic? Can I seal the acrylic with the SPAR seal I originally bought to use over the stain?
I will NEVER, EVER try to stain anything again as long as I live - especially gel on fiberglass. But in the meantime, the last thing I want to do is screw up what should be a simple paint job. Any good, solid advice would be greatly appreciated. Thank you and God bless.
