No they are not. Crushed is like 3/4" or better at least for something like that. Fines are well just to fine.Are concrete fines the same as crushed stone? Would concrete fines be a good material to set a post in?
Drill your hole, 4-6" deeper than required.Are concrete fines the same as crushed stone? Would concrete fines be a good material to set a post in?
Not likely if a crack is or develops at the top edge of the tape .Postsaver or flashing tape like G tape was previously mentioned. Does G tape prevent an opportunity for water to be trapped?
If the crack doesn't continue through the length of the flashing and beyond , then yes i would say the water could be trapped .Sorry, meant to say does flashing present an opportunity for water to get trapped, not prevent. It seems like that is a possibility if water were to creep in somehow
Hello, I live in Florida where the soil is soft and we get strong winds from storms. I am replacing my fence and trying to decide whether I need to put cement in or no cement or use crushed stone instead in posts. I know there is a lot of debate about this. I had a few post break at the ground level and those were cemented in and lasted about 13 years.
Does it help to put cement and above the ground level and sloping away? Would digging a 3 foot hole and using crushed stone instead of cement be good? It will be a board on board 6 foot tall fence
I had a fence once with posts set in cement. When it rotted off at the ground my neighbor came to help. He said "I want to show you something". We dug up the concrete and the post was fully encased in the concrete and rotted off at ground level. This is because rain ran down the post for years, soaking into the post and settled in the concrete encasing. We hit it with a sledgehammer and broke it open. The whole post was totally saturated, waterlogged ith water. Since then what I do is put down a paver first, brick, or something for a footing. I prefer a paver...or pour in a little pea gravel. Then mount the post on top of that and get it vertical and surround it to ground level pouring in pea gravel. The post will not budge. And rain will soak through into the ground and just not sit there for years. Works for me.Hello, I live in Florida where the soil is soft and we get strong winds from storms. I am replacing my fence and trying to decide whether I need to put cement in or no cement or use crushed stone instead in posts. I know there is a lot of debate about this. I had a few post break at the ground level and those were cemented in and lasted about 13 years.
What about all the dirt on 4 sides of the post for 2 feet vertical?This will keep your post off the dirt, drainage of sorts.
notnew2diy, the dirt on either side is just a vertical wall of dirt. There is about 3-4 inches of pea gravel surrounding the post and filled up to ground level. I don't think it ever falls in between the pea gravel if thats what you mean. But, I've never dug it up to look , to be honest. I do know this: once that pea gravel was poured in that post was very firm in the hole. The gravels touching each other provide a very sturdy brace. If you mean will it wash in between the gravels....I don't think so. If it did I doubt it would be enough to rot out the post. I suppose larger gravel could be used too, but my thinking is that would be more susceptible to dirt washing in but over a long time. Another thing I need to point out: The paver (or gravel) at the bottom (before inserting the post) is for the post to rest on and not touch the ground and provides for rain to soak on in to the ground and not just sit there like it does when totally encased in concrete.What about all the dirt on 4 sides of the post for 2 feet vertical?
I don't worry about it. The dirt will not, per se', retain water. It will drain down, like rainwater in a field. The post sits on rock/gravel/a brick/a cookie to prevent the bottom of the post from somewhat retaining water.What about all the dirt on 4 sides of the post for 2 feet vertical?
