I mean, it's an inch. Sounds like room for measuring error to me.
Sent from my Pixel 4 XL using Tapatalk
I mean, it's an inch. Sounds like room for measuring error to me.I was told long ago a fence can go on a property line. I have a survey. I marked the iron pins.
My fence contractor called tonight to tell me he’s starting tomorrow morning. He said he’ll put the fence 1” inside my property line, so theres no chance it won’t pass inspection or have to be ripped out.
I’ve had fences put in in my other houses and this was never discussed. I would say I want a fence along ‘that’ side. It'd be installed, inspected and that was that.
So... is 1” inside property line normal?
Up here in some cities, if it is on the property line the neighbour can paint his side what ever colour you don't like showing thru on your side. :surprise:I was told long ago a fence can go on a property line. I have a survey. I marked the iron pins.
When I moved into my last house, I quickly noticed the fence beside my place did not look right. The city had a path to a park beside by place, and put the fence very significantly on my property (6' at the back, 1-1/2' at the middle and 3' towards the front). City tore it down and rebuilt it, shifted over. But a while later I was talking to a lawyer, and after 10 years, city would have the right to leave it there (it had been 7 years at that time).(I suppose theorteically, if you had a very strange neighbor who proceeded to use your 1" of land over a period of 18 years (varioes by state), without any objection by you, could at relatively large expense to himself, go before a court and claim that land under eminent domain.
Same here, in the DC area. I think my county allows approval letters from neighbors if you want to come closer than 1' to adjacent properties, to account for neighbors who may want to go in on a fence together (i.e. you and your neighbor both want to put up a fence right on the property line, and share the cost).Contact you local zoning dept. in my area that fence should be at least 1' away from any property line.
Unfortunately a survey is just the opinion of one surveyor. If someone disagrees they hire another surveyor to get a second opinion. My property has a 20' dispute on my lower line but I really don't care, it is a wet area and I don't need to pay more taxes. But disputes are very common and many end up in court. Older properties are the worst, that old tree is gone and the stream used to be over hereHe said my survey was wrong it was off a couple Of feet. I don’t know surveys were ever wrong. I thought a survey was like the word of God but anyway at this point I don’t care where he puts the stupid fence
Surveyors who give second opinions are surveyors you don't want to deal with. The metes and bounds are what they are based on your county property records, and GPS surveying equipment means there should be no disagreements.Unfortunately a survey is just the opinion of one surveyor. If someone disagrees they hire another surveyor to get a second opinion. My property has a 20' dispute on my lower line but I really don't care, it is a wet area and I don't need to pay more taxes. But disputes are very common and many end up in court. Older properties are the worst, that old tree is gone and the stream used to be over here.
