Installing pvc fence tomorrow(with friends) and have watched some videos. If the grade slopes slightly do i keep the bottom rail the same distance off the ground the entire way or make sure the top is level the entire way?thanks
Sent from my SAMSUNG-SM-G935A using Tapatalk
· JUSTA MEMBER
Follow the contour of the ground over long distances.
If you keep the top level, you could easily have a 2 - 4 foot space under the fence at the lower end of your run.
And that defeats the purpose of a fence.
Of course vinyl fence is just ornamental, but will still look ODD if there is a higher gap on one end than the other.
ED
