I am running a 60A subpanel out to my new garage. I dug a trench and laid 2" PVC conduit from the basement to the garage. The issue I am having is that the main service panel in the basement is in a finished room, and I can't run rigid conduit to it. I will have to snake the wires through a "soffit" to the panel. The soffit hides pipes for our kitchen sink, FYI.
What are my options? From what I have gathered, I can't run the standard 2-2-2-4 AL SER cable you can get at home depot because it isn't rated for direct burial. And I can't just use wires that are rated for direct bury loose in the soffit by the main service panel.
Is there feeder cable that is rated for both burial in a conduit and loose in the soffit? Or is there a flexible conduit that would be large enough for a feeder cable?
