So, here I am trying to wire up my shop. The plan is to swap the main feed from the house, to the shop and have the meter for the property on the shop and then run the feed through the panel (via the feed through) back to the house panel (Feed for the property is ten feet from the new shop and much closer than it is to the house).
My concern is that the new panel is 200 amps (with a feed through), the existing house panel is 200 amps. I'm only going to be needing about 100 amps for the shop. Mainly just a welder on a 50 amp breaker, some lights and a few outlets. I can't find any info on what the feed through rating is for the panel. I'm assuming it's not greater than 200 amps as that's what the main breaker in the new panel is rated at.
So if the new panel is rated at 200 and I need a feed off the panel of 200 amps for the house would that max it out and not allow me any amps for the shop?
This is the panel.
Siemens
Model # MC0816B1200RJBT
Hope I made that clear and intelligible.
Thanks!
This is the panel.
Siemens
Thanks!
