1 - 9 of 9 Posts
The tub in my house has an 8" old style faucet; that is, a hot valve, a cold valve, a center diverter for the shower, and a tub spout. Yesterday the water pressure was fine coming out of both sides, today the hot side has hardly any flow at all. Cold side is normal, and both hot and cold on the vanity next to the tub are working fine. Any ideas what may have caused this?
Could be a number of things? Does the handle free spin on the stem? Could be a chunk of rust or calcium that made it past the seat into the stem. Could be the gasket on the stem ripped and is blocking the water. I would suggest shutting off water and removing the seat and stem. Replace with new one or remove obstruction.
OK, the handle does not spin free on the stem. The piping is all brand new Pex, and it is not frozen. I know for sure because A) it's inside the house and B) the vanity faucet is fed off the same line as the bath tub and it works fine. I pulled the stem out and looked inside the faucet body and I do not see any obstructions. The washer was pretty well flattened out but not torn or raggedy, so I replaced it. I also disconnected the supply on the back side of the faucet and looked in there. No junk, goo, rust, calcium, or chunks of anything inside. The handle (stem) does seem a bit hard to turn, but I don't know why that would cause the flow to be restricted. As I said on my first post, the cold side works fine and the hot side of the vanity has good pressure. The hot side on the tub is barely a trickle. Suggestions? It's a Central Brass faucet, if that matters and is probably over 50 years old.
1 - 9 of 9 Posts
