Over the weekend I replace the leaky cartridges in a Moen bar sink...individual hot and cold. The faucet was installed in in the mid 70's, functionally clean not loaded with mineral deposits, exterior finish just shy of looking new. The hot cartridge came out with some convincing, the cold did not. The lower half of the cold cartridge broke off inside the valve. Which would explain the drippy faucet, you could tell it must have been cracked for years.
My question is is there a tool that assists with the removal of the faucet cores? My method was crude and while I'm certain, it didn't cause it to break, most likely it didn't help.
I ended up removing the faucet from the sink, and finding a small punch to drive the broken part out from the supply side.
BTW...this series of Moen faucets now have life time warranty on valve parts, the one installed did not. Moen helped me locate a new part number that "should" work, but did not have them. After getting a referral from Moen, I called Kully Supply, Inc. www.KullySupply.com; Phone: 800-518-5388 (shameless plug for a company that filled a need), they had the out of production part and given that I worked with Moen to identify the part number, if it didn't fit they would take it back in return with out a restocking fee (all I'd be out was the shipping). The parts were not cheap, but the replacement faucet was in excess of $450, so in comparison, $75 in parts wasn't out of the question. The second generation part fit perfectly and the 30 year old faucet works PERFECTLY!
