I plan to lay some vct in a small room (~100sq ft). I removed some badly cracked vct and did an entire coat of fastpatch to even out the floor. Bad thing is, it didnt come out even.
Should I plan on sanding the floor to even it out, or pray that the glue will even out the floor on its own?
· Tileguy
VCT adhesive isn't going to fill anything or make any corrections. In fact, if you get it too thick your life as you know it will be over.:)
I'm not familiar with Dash Patch but unless you know what you are doing you stand little chance of flattening that floor with just any cheap patching compound and a trowel. As Mike has said; the materiel needs to be a Portland based compound.
Better yet...use Self Levelling Compound.:)
