1 - 2 of 2 Posts
I have used several methods over the years.
Backwards blade in circular saw with a jig, sliding mitre saw with backwards blade, and various forms of tin snips/aviation snips.
Recently I started using s small grinder with a thin metal cutting blade. this is easily portable, can even be used right on the scaffolding.
So I was wondering what method do you use and why?
journeyman carpenter
if its warm enough outside snips.. no chords to run... no loud whining blades.. some siding guys i know use the shear that can cut laminate flooring.. it makes a perfectly square cut and its super quite.. no vinyl shavings in the air
1 - 2 of 2 Posts
