1 - 9 of 9 Posts
Not at all.
Are you considering doing it, or some, "CON-tractor?"
#2 pine or cedar are the most commonly used wood fascia materials used.
Ed
Only if you want to replace it when it falls apart
You are referring to the OP's suggestion of considering using OSB, not referring to the pine options, right!
Ed
I actually use 2x lumber for fascia
No problems securing my gutters, or anything else
good idea Dave
Only if it is New Construction.
If this is an existing roof, the additional width will not align with the existing Gutter Apron sheet metal drip edge flashings and the extension of the current shingle overhang.
Ed
1 - 9 of 9 Posts
