It was suggested on another thread that we sticky common information, I suggested that we just develop it into a FAQ, since we definitely have certain frequently asked questions.
I was thinking maybe a rundown of MWBC and their unique failure modes, or a link to a good description of them. That seems to come up a lot.
Subpanels, as was mentioned, and neutral/ground isolation, objectionable currents.
Some Q's to get us going:
Q: Why must the neutral and ground be separated at a subpanel?
A: Because if they are tied together at a subpanel, current will flow on both the neutral and ground wires. This can cause a situation where a broken neutral wire between the subpanel and main panel would float all the chassis of every grounded device up to line voltage! The same danger applies to "ghetto grounding" outlets, where the neutral wire is jumped to the ground screw.
(insert picture of that sort of dangerous fault)
Q: What purpose does a grounding rod serve?
A: Lightning protection only. Very little current conducts through the grounding rod during normal operation, because the earth is a relatively high resistance connection.
Jump in and add more if you want.
