Hi, I have a 120v 4.5amp 1000rpm (1/4hp) 3 speed furnace fan motor and want to use some sort of Fan Speed Controller to lower the RPM down to about 1-4rpm without losing amperage and hp.
I've tried this with a blender motor and it took about 2-3 fan speed controllers to get it under 15rpm. So im wondering if this motor is too powerful to stop or not? its about 6inchs diameter.
also the motor I have is a 3 speed motor and along with the two power cables has a four pronged connector with labels L M H C, anyone know what those are for? or if the motor will burnout if I dont set the speed?
-Thanks, Noob
Also I just tested it and connecting the power wires to a 120v source does not make the motor turn, I tested it with a FSC and direct to the 120v power source. I tested it with a volt meter and it doesn't look like its burnt out.. any suggestions?
-Thanks, Noob
