I'm replacing a Hunter ceiling fan that is pushing 20 years old. No issues with it - just looking to update the style. I'm actually going to reinstall it in a spare bedroom.
The replacement is a Allen & Roth (Lowes) 52" with remote. I'm really not interested in the remote, so I connected it to the existing fan/light wall control. I have a similar fan with a remote, and slow is not quite as slow as I would like for just moving air. I don't see much benefit with the remote since I am already wired for dual control, and I'm sure the remote will always be on the opposite side of the room when I am laying on the couch, assuming the dog does not chew it up by the end of the week.
The light is dimming fine, but I seem to have no speed control on the fan - high speed only. I'm guessing a shorted triac in the fan control.
The manual makes no mention of using a speed controller, other than in "troubleshooting" where it is not recommended to use a solid state control because it may cause noise/hum. The old fan would hum at low speeds, so I usually left the control at max and used the pull chain to vary speed. It is possible the wall control has been shorted for years and I never noticed. Picture attached in case anyone recognizes the old control, if it matters.
Is it possible that a modern fan would blow an old control? Any recommendations on a replacement wall control that can share a dual gang box with a regular light switch?
Also, any issue with using the remote with the old Hunter fan? (Assuming I can fit the receiver in the canopy).
