Typically the thermostat wiring goes as follows:
Red wire to R terminal
White wire to W
Yellow wire to Y
Green wire to G
If the thermostat has RH and RC terminals you need to jump them together.
The furnace is wired the same as above except the RH and RC don't apply.
Also at the furnace you should have a set of wires coming from the condensing unit. These wires are usually Red and White, but not always.
One of these two wires should be connected to the Y terminal along with the yellow wire from the thermostat. The other wire is connected to the C or Common terminal. Hope this helps.
White wire to W
Yellow wire to Y
Green wire to G
