My panel has a arrmor protected ground wire run to the water lines. There is a similar jumper around the water meter. The existing line to the street is steel, but needs to be upgraded due to much corrosion.
The person who put in the breaker panel for the previous owner made a "fake" ground connection. It consisted of about 8 inches of ground rod, appropriately smashed and dented up on the top as if it had actually be driven into the ground. This he dropped into a whole in the floor which isn't even drilled all the way through the floor slab. It was held in the hole with some sort of putty or caulking type stuff. I guess it tricked the inspector, who gave the whole job an "Accepted" ticket.
I realize that I need a ground rod to supplement the water-pipe ground -- especially once the water main is changed. How and where should I install the new ground rod? Should I just try to drill all the way through the slab (and also part of the footer below it) where the "fake" ground was located, or should I start with a fresh hole through the basement floor below the electric box? The meter is inside adjacent to the breaker box. Will I need a second real ground round once the water line is changed.
