I live in S. Texas, where 100+-degree temps are common in summer. The air-handler is attic mounted - due to insufficient attic ventilation (which I'm also working on), attic temps get upwards of 135 on a 100-degree day.
As I said, I'm working on the ventilation issue, and I'm also slowly replacing the R4-insulated flex ducts with R8 ducting. Since the air handler is sitting in all this heat, I'd like to improve it's insulation as well. One method I've thought about is rigid-foam sheets strapped/glued around it (with access to the access panel) - any other ideas? And is this worth it (bearing in mind this would also help in winter)?
Thanks!
Thanks!
