Hey all, I live in a garden condo in Chicago and am starting a front door replacement project. It's a builder grade wood door and it's warped over the years and doesn't shut correctly. I've purchased a prehung steel door to go in its place. The old door is a very odd size 39W. Height is 84". I have bought a standard size 36x80 door to go in its place. I've torn out the drywall around the door opening and they used about an inch of wood to frame it between bricks on the bottom half and about 4" of wood on the top half (brick opening is wider up there at ground level).
The old frame is floating above the floor. Is that normal for a concrete floor? I want to attach my new frame to the floor so it's sturdier. So far I know I want treated lumber and I'm pretty sure I need to put something between the wood and the concrete so we don't get any rot down the road. Do you guys normally use like a metal fencing bracket where you nail that into the concrete then nail the door frame into the bracket?
Also, I'm not gonna have enough room for a normal king stud/jack stud frame since the bricks are too narrow, at least on the bottom. I feel with the extra 3" I gain with the narrow door it'll be much better than the old door frame.
Any other tips/tricks are appreciated. I'm a home improvement novice but am very meticulous. If this were a normal front door on a normal house this project would have been done already
