What do I do with this gap around the window between the house and the brick mold?
I'd just caulk around the sides and not the bottom, that way any moisture that did get in would have a way out.
What's up with the missing piece under the window?
The window has a built in J trim, so the brick mold is an inch away of the flange:wink2:If you cannot push the window in until it presses against the siding, doesn't that mean you ordered your windows too large?
If the window is the right size (it fits inside the rough opening), do you need to remove the interior trim and cut it to the new required width?
That's funky.The window has a built in J trim, so the brick mold is an inch away of the flange:wink2:
