I moved into a cedar-sided house that was stained about 14 years ago -- I believe they used Columbia Paints Duron in a semi-transparent finish. Surprisingly, it has held up very well except where the sun beats down and where snow accumulation/water are an issue. I am afraid of trying to restain with a semi-transparent at this time (blotchiness and uneven color as well as absorption).
1. Can I use a semi-transparent and get even color results?
2. Can I use a latex solid stain over the semi-transparent if indeed it is oil based. If so what preparation do I need to do?
3. Any other things that I need to consider when undertaking this project? I have cold feet to an extent because it is a 5000 sq. ft. DIY project!
Thank you!!
· Premium Member
At this point I doubt you will get even color results by re-coating with a semi-transparent. I would re-do it with a solid color stain, something like Sherwin-Williams Woodscapes. As long as you clean the surface thoroughly to ensure proper adhesion, you will be fine.
WoodScapes is a really good stain.....It's tough to get a uniform finish with a semi trans even for a pro.....you have to do it in squared of sections and work fast to keep it blending. This is a house I did 4 years ago with solid WoodScapes. It is ocean front and has held up very well.
Like GS said, I would use a solid it will work fine over a semi. If the original lasted 14 years it was an excellent product....Stain in general lasts longer than paint on any siding but 14 years?....That was a great product.
