1 - 7 of 7 Posts
My local code list 3/8 or 1/2 inch OSB on 16" OC studs for exterior walls. I am ready to hang 7/16" OSB thinking it falls in-between the sizes listed somewhat. Before I put nail to OSB, would 7/16" work? I am in Virginia, my county goes by state code. Thanks for any advice.
· journeyman carpenter
7/16 is the standard for most regions, i often use 15/ 32 soley for the reason that its the thickness required on the roof here we just buy one thickness so there is no mixing up sheets. mind you depending on teh budget for the project we can sometimes up sell to actual plywood
· Registered User
Reactions: woodworkbykirk
1 - 7 of 7 Posts
