1 - 14 of 14 Posts
I have a problem with birds nesting in exterior dryer vents. My vents are wall mounted on a brick exterior. The flap type don't prevent the nesting, as they hang open enough to let the small birds in. I have seen the Heartland vents on the web...do they work? Any other suggestions? Thanks.
· Registered User
Can't speak for everyone else... It may not be exactly like this . but It's close. If you've installed any ..You should know that there are many on the market...The ones I install are approved for dryer venting.. gas or elec.
The pick you posted is only for air conditioned environments though right?
It's not for an attic application where the tube would need to be insulated.
BTW per code, is a 4" diameter rigid tube required for the attic?
I've never seen insulation for rigid tubes sold at the big box stores though.
· HVAC / Plumbing
Depends on the area your in as to what code would be... Any metal dryer vent is code here ... insulated ??? Not required here... I was only refering to the termination part of the vent to keep birds out.. not the entire vent package... You would need to install what ever is code for your area... Insulated or not
One should check the manufacturer's restrictions to ensure it's for the right application. I've seen those at the HD, and they clearly state not for dryer vents.
· Chicago, IL
What the dryer manufacturers typically recommend (always follow the specific installation and use instructions for your dryer):
1 - 14 of 14 Posts
