A "Handy Husband"
Usually the rough is 2" wider than the door. If your jacks are exactly plumb you may get by with 1.5".
Otherwise widen the opening or buy a 30 inch door.
Don't just beat on the studs. You may be weakening the header above or split/damage the studs, trim, esp where they meet the top and bottom plates. Maybe you can move about 1/8-1/4. Rest you will have to remove with a chisel and parts with a saw. Use cheap saw blade and saw through the nails. 1/2" deep at a time. Refasten the studs.
