Hi,
We moved into this house last fall and now that we're getting outside I've noticed along part of the bottom exterior it has started to crack/chip away.
Above this area is a deck and I suspect this chipping of the brick has been an ongoing issue building up prior to us moving in.
I'm wondering if the reason this is happening is because the landscaping stones we're installed too high? They are slightly above the flat foundation wall and instead touching up against the red brick. Note the screen door area is coming out of a walk out basement.
Is this a minor issue I can fix myself or a major foundation issue I should be concerned about and check with professionals? Any insight would be appreciated thanks!
