Appliance flex connectors cannot be concealed in a wall- not code compliant
So what about these two options:Appliance flex connectors cannot be concealed in a wall- not code compliant
Several supply shops will sell the CSST cut to length, so maybe those same shops will add the connectors for a fee. My install has gas lines in the attic. A wall opening behind the stove prevents a direct vertical run - thus the horizontal run.Although the tube may be same but the connectors are different and there are rules about how the yellow tube can be installed. Im thinking of doing this diy (but the town may not let me diy) and will need at least the tool that crimps (?) the permanent connections. I also need to find out if the permanent connections are sold to anybody.
Can you come through the floor than a wall?
Hadn't thought of that, and it is the best solution. With this being behind cabinets, and my plaster about 1" thick, I won't need to notch much to make it flush with the wall. I could even add a recessed shutoff box.Why not just notch the joist and use black steel gas pipe? Not like your going to put a nail through that.
