1 - 9 of 9 Posts
· Premium Member
Nicely done! It is all the rage these days. I've done two of them in the last couple months. One, black, one gray. I think the trend is here to stay.
Discussion Starter · #6 ·
Looks good. This is what I'm planning for my basement ceiling as well.
For the can lights, you just sprayed the cans & frames? Are they IC rated? I'd be a bit worried about burning off the paint...
They are IC rated, haven't had any issues with the paint burning at all... just make sure u mask the outlet. Good luck, looks even better in person...
Sent from my SM-G900P using Tapatalk
· Registered User
Looks good... don't see it too often as many older houses have less than 2x10 joists so they have to cover it with 1/2" drywall against fire, per Code:
#4
; http://publicecodes.cyberregs.com/icod/irc/2012/icod_irc_2012_5_sec001.htm
That, and one should always check with their HO Insurance carrier as they may require it per local amendments to the code, and not cover it if ever a claim.... Wood 2x joists have a 8-12 minute burn time--- double that with 1/2" drywall.
Note, the joists above the stairs have a pipe running perpendicular to them, drilled very low to the bottom of joists-check for 2" of meat left, per code- otherwise the joist rating drops one size...; http://publicecodes.cyberregs.com/icod/irc/2012/icod_irc_2012_5_par025.htm Maybe just my eyes- because it all painted black, lol. Welcome to the forums!
Gary
Reactions: joseph.k
1 - 9 of 9 Posts
