1 - 7 of 7 Posts
Have been reading and posting about my detached workshop/garage. Getting ready to connect it up so looking for the bits and pieces needed to git-r-done.
Anyone have experience or comment regarding the GE 100-Amp Workshop Panel Kit available via Lowes for $54.00? Includes 100amp main breaker, a few 20amp breakers, 12 slots, and the ground kit.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=214802-76863-TM1210CCUG1K&lpage=none
I would be installing it in my detached garage, feed it from a 60amp breaker over three #6 wires with a #10 ground in about 100' of 1" conduit.
12 circuits on a 100 amp panel not so good.
It's 12 slots and 24 circuits, so it says. I will only have maybe 1/2 the slots used, leaving room for forseeable expansion methinks. 24x30 garage/workshop for me working solo - so seldom multiple tools in use at the same time.
The 100 amp main breaker is a disconnect, panel fed with a 60 amp from the main panel.
1) 20 amp lighting
1) 20 amp general usage outlets - shop floor (table saw, chop saw, etc.)
1) 20 amp general usage outlets - workbench (bench grinder, drill press, etc.)
1) 20 amp small compressor outlet
1) 30 amp motorhome jack (only used for storage and occational maintenance / exercising the RV)
1) 220v 30 amp welder / plasma cutter
Your plan sounds good and the price seems very good. I don't think you could buy that 100A main for $54
It depends entirely on what the circuits draw.
A dozen baseboard heaters...not so good.
12 circuits broken up for individual receps and lighting?.... great.
The fewer receps on a circuit, the less chance of overloading an individual circuit.
In a shop, I would install a dedicated circuit to each recep, just because. You'd spend 4 bucks on a breaker and a few more bucks on extra wire but you could then use any tool anywhere.
Discussion Starter · #6 · (Edited)
I like that, would only add a couple more breakers for the general usage receps - as there are basically two wall areas with receps. The other two - built-in storage cabinets are along all of one 30' side wall, and a 16' double garage door in a 24' end wall. Thanks!
1 - 7 of 7 Posts
