The thing with the jack hammer (your way would not work with my slab because it's secured to the house) is I have to rent it, and do it all that day or at least in a few consecutive days (don't get those often) or it gets expensive, if I drill holes I can just drill them at my own leisure when it's not as hot out, or even at night (though it might be kinda loud).Good gravy, if you are going to drill that many holes just get two or three hydraulic jacks, jack the edge of the slab up and pop it a few times with a sledge hammer, it will crack.
Cool, I'll check that out, thanks.Looks like Crackamite is only in India. Found this site with an 800 number in the U.S. http://www.dexpan.com/index.aspx Even has prices and looks like you can order on-line. Credit cards accepted. If you get some, be sure to post your results.
And if you can't, have a next of kin post for you.If you get some, be sure to post your results.
I remember the thread from not too long ago. The stuff worked fast and well. Hope you can find it. It had great pictures.Yeah, Dexpan. Never used it, but there was a thread on it a while back.
http://www.diychatroom.com/f19/concrete-demolition-105076/index2/
Hammer drill might help? Do you have tool rental place? Ask them. Strikes me you might be better off renting something you might not use often again?Amazon.ca does not have it but guess I can still order from the .com, I'll just have to pay the border taxes. I'll have to ensure I order the right amount and make it worthwhile. Border taxes are usually about 100-200 bucks.
I will drill the holes first though, just to see how much of a job that is. My bit always slips in the drill chuck making it harder, I need to figure out a solution for that. I'm wondering if I should buy a bigger drill, like a 1 inch chuck instead of 3/4.
I was thinking this too, think it would actually work? I could wait till February-March when we get -40's and go fill them with water and cap the tops with snow.If you plan to wait til winter, drill your holes, fill with water and let the winter cold freeze the water and burst the concrete.
